Hi, can i ask some question ?
what i allready do :
1. rip BD using anydvd
2. make iso using imgburn ( with UDF 2.5 )
3. mount it using daemon tools
4. play it using power dvd 7.3
5. using anydvd running
6. install udf 2.5 drivers ( my OS XP pro )
"google" tell me mostly like above...
but i still can't play the iso...
anybody here have another way to play it ?
thanks before for the answer...
you need to pro version of daemon tools (free version doesn't work) , or the free virtual clonedrive
thx for the answer, i allready do that, still can't...
power dvd didn't give me any warnings, but only show black screen...
same with arcsoft total media theatre, only black screen... -
Are you using a version of PowerDVD that supports BD -- can you play the original disc -- can you browse the original disc in Windows Explorer -- can you play the title m2ts file, or the video extracted from it?"but i still can't play the iso...
anybody here have another way to play it ?"
With apologies if some of these questions sound silly, but if you can't play the original, or browse the original disc, that's a show stopper. Though I've seen 1 or 2 exceptions, you should be able to also drag/drop/play the m2ts in PowerDVD & you should be able to play the video in it's native format -- avc & vc1 will probably need to be in an mkv or avi container for that to work. If you can't read udf 2.5 discs or play the BD video by itself, you may be looking in the wrong place trying to figure out why an iso isn't playing. If everything works good up to that point, verify your iso contains the right structure in udf 2.5 format to be recognized as BD or AVCHD. If you can mount your iso properly you should also be able to drag/drop/play the m2ts from there. While it has it's good & bad points, CinePlayer BD will play BD on your hard drive without 1st converting to iso, as well as some discs PowerDVD doesn't seem to like [e.g. BD-spec 720p mpg2 BD5]. -
Free version of daemon tools works for me.
Play AVCHD Iso
By yardline in forum Software PlayingReplies: 3Last Post: 25th Jun 2011, 01:44 -
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 16:51 -
1080i .TS Video file to Blu-ray .ISO file Help !
By SiNnOFf in forum Authoring (Blu-ray)Replies: 19Last Post: 3rd Nov 2010, 14:12 -
How do I play an ISO file?
By OM2 in forum Authoring (DVD)Replies: 3Last Post: 2nd Mar 2010, 17:44 -
How to play ISO file?
By jyeh74 in forum Newbie / General discussionsReplies: 14Last Post: 24th Dec 2009, 13:04
